Hello gang. I've only been using Inventor for 6 months but I have 8+ years of NX modeling experience prior to this job opportunity. These forums are quite awesome and I'm posting for the first time. Please be gentle.
I'm currently trying to model a conical transition (read contour flange). I've been able to use the Unfold/Refold command successfully and easily created a flat pattern. I was even able to add some chamfers and a hole cut in the Unfolded state since that's realistically the easiest method for our shop folks.
This all worked splendidly until I tried to chamfer the outside edges of the part. At that point, my flat pattern turned into a Picasso painting of some sort.
I have tried all sorts of things, but as soon as I apply an chamfer to these external edges, stuff goes sideways real quick. If I suppress the chamfer, the world gets better again. Either of these 2 edges causes the problem even if I only select one of them.
Note that this material is 1.25" thick and doesn't qualify for the classic definition of Sheet Metal. In my world, though, this is thin stuff and we roll it and treat it like most shops would treat thin gauge material. I don't think that has anything to do with this "glitch", but I'm sure someone will notice that wrinkle in the fabric and point it out.
I've attached the .ipt file for the wizards out there.
My apologies if I've violated any basic posting etiquette. Thanks in advance.
