Content Centre Libraries - Fasteners explanation of Standards
110_turner
110_turner
Hi
Does anyone know of an explanation document regarding the different international standards of fasteners available within Inventor.
I get that if you are working in industry you / your company will know the specification of the fastening products it needs to specify and buy but as i am not in that position how would I go about creating appropriate exambles of fabricated assemblies for my pupils.
Being in the UK I know that I could use BS or more likely ISO but what are the differences and which should be used where?
regards
David
PaulMunford
You are correct. Use BS or ISO standards. If you are unsure, contact your local hardware stockist and ask them what standards their stock comply with 😉
Paul Munford
Technical Onboarding Architect
Linkedin
110_turner
Thankyou    I actually tried that some time ago - probably to vague a question - but they said they could get whatever standard I wanted rather than anything about the intended or likely use of all the different BS or ISO
Might extract a list of those particular BS and ISO and take that to them and ask a slightly different question - does Inventor have the name or title of each individual standard stored anywhere that could be brought into a display column perhaps ?
thanks again
regards
David
PaulMunford
Hi 110_Turner,
Can you clarify where you want to see the standard? ie, in the BOM, in a parts list etc.?
To control which libraries are loaded - use the libraries button in the projects manager.
To control which libraries you can see, use the filter in the content center.
To see the standards column before you insert a part, show the families grid in the content center insert control or editor.
For insert parts, the standard usually makes up part of the filename/part number and description.
Does any of that help?
Paul
Paul Munford
Linkedin
