Content center not working.
Stahle
Stahle
I have just recently upgraded to Inventor 2022 from 2020. The delay was due to needing to upgrade Windows.
We work independently, not on Vault. Each project contains its own folder / project  for content center parts.
Since upgrading to 2022, when I create a new project and try to use the content center, a large number of the catagories are missing.
When I open an existing project, all the catagories are there (specifically the fasteners).
I have tried every trick I know to make it work.
I have worked in Autodesk products since AutoCAD 2.......it continues to amaze me at the things that will stop working from version to version.
I have included 2 pictures, one is from an existing project (top), one is from the new project (bottom).
CGBenner
@Stahle
In your new project file are all of the libraries you want or need set up and active?
Chris Benner
gregory_nickol
I'm assuming the new projects are being made from scratch? My first guess would be that in the new project you need to configure which content center libraries it searches for. In the screenshot below, from the project list you can click the button on the bottom of the right side to open the configuration dialog box. Then from there my GUESS is that the libraries you want may be listed there but unchecked. In my example image, I have my custom content library there, and everything else is read because I want the projects to be ABLE to see them but I actually moved them out of the folder and only move them back in to copy over components we need rather than have everything from all the libraries visible. Personally for new projects I don't actually make new project files from wherever the default template is stored, I go through the file browser and copy, paste, and rename a "template" project with my standard libraries.
Stahle
Yes, it seems as if there was an issue with the Default.ipj file.
I corrected and replaced it and it is working fine now.
Thank you.
