Content Center Missing Possible Because Of Two Monitors
This widget could not be displayed.
This is what happened:
I am using two monitors. I was having problems with one monitor and had to switch the two around and shutdown my computer. After doing this the monitor problem was fixed but now I cannot access the Content Center in Inventor. When I am in an assembly and click on the "Place from Content Center" button it seems as if the content center opens but I can't see it anywhere, nor can I grab on to it and drag it into view from either edge of either monitor. I am not getting any error messages that pop up which leads me to believe that the Content Center is opening, just not in view. I would like to fix this problem without having to re-install Inventor. Any suggestions?????
When you launch content center, press alt+space, then M. Use arrow keys to see if you can bring the window back on screen.
Or try the Alt^tab key and see if you can cylce the
Content Center to the main window.
Dell Precision 690
Dual Quad Core E5320 @ 1.86GHz
AIP 2009
sp1 - D3D
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro
FX3500 256Mb - Driver: 176.04 Bios: 5.71.22.55.08
XP Pro Sp3
3Gb/2800
Space Explorer USB, release: 3.6.7 driver 6.6.1 firmware 3.17
When
