Content Center Libraries not availible after update
ANDYPITT1573
Message 1 of 34
ANDYPITT1573
I updated inventor to 2022, but now I can't access any content center libraries.
The default libraries are listed as "Not available", and my custom ones are "read only" even though I've set "Use Style Library" to "Read-Write"
I have tried to to install the 2022 content centre libraries, but when I try to modify the installation all I get is this:
When I navigate to the default folder, It's empty.
I saw reference to launching setup.exe from the install folder, but when I look for it I can't find it.
Does anyone have any advice for how to
  1. Get the updated 2022 content centre libraries
  2. Update my custom libraries
Thanks!
Replies (33)
Message 21 of 34
Patrick_DB
Thanks for de reply
Are the 2023 library files from the 2023 install?  Yes
Message 22 of 34
AleksanderMyklebust5924
try to make a new project.
Single user
Select the content center and press update tool.
See if there is any error messages then.
Aleksander Myklebust
Message 23 of 34
Patrick_DB
[cid:image001.png@01D8F357.1CCFBBB0]
Same problem
Message 24 of 34
Patrick_DB
Message 25 of 34
BDCollett
The location you are showing are not the default install for the libraries:
They default libraries install at:
C:\ProgramData\Autodesk\Inventor 2023\Content Center\Libraries\
Copy them from there to that other location shown via the project file and they should work.
Message 26 of 34
Patrick_DB
Problem solved. Thank you.
Weird, in version 2022 I could put the library in any folder?
Message 27 of 34
BDCollett
Nothing has changed from 2022 to 2023 in regard to the standard libraries.
They can go in any folder; you just need the specific version of libraries for your version of Inventor.
Message 28 of 34
Patrick_DB
Yet here I have that difference. If I copy the 2023 library and link it to another folder, it doesn't work. I don't have that with Inventor 2022  🙂
Message 29 of 34
I do not use the standard folder (INV2023),
so just copy your folder to the new location and rename the folder.
Link to the new folder and it should work as long as you can read and write to that folder.
Message 30 of 34
BDCollett
I have moved the default libraries in 2023 and every other version for as long as I can remember just the same way.
Either there is a permission issue on the folder, or you are linking the location in the wrong place.
Message 31 of 34
leonvanstrien
This worked for me !!! Thanks!!
Message 32 of 34
dom.ashV9SWY
Hi, I've had a very similar problem, although I haven't updated anything recently. It has all been working happily until today when I tried to use Content Center for some reason all of a sudden none of them are working, any suggestions?
Dom
Message 33 of 34
Hi, we use OneDrive to sync these libraries over remote users.
So instead of using local installed folders, we read a common OneDrive folder.
Message 34 of 34
dom.ashV9SWY
Thanks Aleksander,
I'm the only user we have so syncing the files should'nt be a problem. I can't understand why the libraries aren't working as I don't think anythings changed!
Dom
