I create 2 new libraries in my Content Center (fig 1), whit some of my standard pieces that I use a lot, I can use it normally, but since yesterday afternoon, I can't use it any more, as you can see in the figure No.1 there are in use, but when i open my content center, figure No.2, you can see that I can see the two new folders (EDS, ESA), but you can see in the history some of the pieces that I have in these folders.
My colleagues have access to this parts, they can see the folders in their content center, the issue is only in my computer apparently, how can i fix it?
Thank you.
Fig.1
Fig 2.
Solved by Mark.Lancaster. Go to Solution.
No images attached..
Not sure what you are trying to show in image #2. Image #2 is based on the search and not sure what you mean history. Also I notice you have the filter option selected. Are you filtering based on your standard or some other standard?
Mark Lancaster
& Autodesk Services MarketPlace Provider
