Content Center is making me lose my mind....
Jef_E
Message 1 of 21
Jef_E
Hi!
We are a company with +10 Inventor users and we use autodesk vault to manage our files. To manage the content center we were advised to put out library .idcl file in vault, check it out when there are changes and check it back in into vault when done. All the other users can get the latest edition and use the c/c locally.
I made a change recently to a column that first had text into it and now I just had values so I could map these to user-parameters. This change got trough for a few user ( I checked by getting the latest .idcl on some computers ). A few days later there was a user complaining that something was causing an error, which worked fine for me. I check the c/c family at that persons computer and the column still has text in it.. Strange because he did GET the last version of the .idcl but I didn't check it there.
Now I made another change to the c/c for another family, I added a column and again check the file in. Now the first user that I checked doesn't have the new column.. ( this is a different user then the one that has the previous problem ). Then I checked other users they all have the new column available, and the user with the previous error does too ( but there the previous error still persists ).
What can I do to solve this? I need ALL users to have the SAME content center available without a doubt. How can I get their c/c the same as mine and all other users? What is causing this problem?
This problem is interfering with the automation tools we made..
I'm getting really crazy by the content center behavior...
Please help.. i'm at a loss here.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (20)
Message 21 of 21
Jef_E
Tomorrow is a really bad timing, I am swamped with work.. I will discuss it with my superior and inform you. In the meanwhile maybe @Mark.Lancaster knows the solution.
Inventor 2014 SP2
