Content Center - hex nut placement exits command
3D4Play
3D4Play
When I try to place a hex nut using CC, <right-click> <Change size> cancels the command. Clicking to place also cancels the command. The only way I am able to place a hex nut is to <right-click> <place>, which brings up the size table to select the desired size, which can then be placed - but only one instance at a time per command, hence a very slow process.  This is different behavior than when using Auto-drop, which tries to autosize the nut, actually lets you place the nut - any size, correct or not - before changing its size, and allows placing multiple instances. I don't recall having this issue before 2024 - is this a new feature?
Here are the steps to replicate this, within any assembly (see if anyone else has this issue?):
  1. Place from Content Center
  2. Drill to Hex Nuts. You should then be transported to the screen with a hex nut magnetized to your mouse cursor, with the red auto-drop symbol present.
  3. We just want to randomly place multiple instances. Click to place anywhere in open space, i.e. don't use Auto-drop. Blink. Command exits.
Or, use these steps for a different approach:
  3. Ah - I want to change the size first! <right-click> <change size>. Blink. Command exits.
Am I missing a setting somewhere?
johnsonshiue
Hi! This is a known issue, which has been fixed on 2024.1.1 update. Please install the update.
Many thanks!
Software Test Engineer
3D4Play
Done, and fixed. Thanks!
