Content Center - Flange
I want to have a reference plane in my content center flanges to indicate the start of a pipe.
For example in a Weld Neck it will be at the top of the flange and for a Slip On, it will be X amount from the raised face.
The idea is to have this common plane of reference where by if I change from a Slip On to a Weld Neck, the pipe constraint changes accordingly.
The plane of reference is called "PIPE CONNECTION" here:
Unfortunately, when doing the trial in an Assembly and trying the "Replace from Content Center" option, it does not work.
See here pipe constraint gives errors as it lost the plane:
One way that I thought of doing this, was setting this reference plane at the Origin. But it's not acceptable as we need our origin at the raised face, since we use this for everything after.
Any help or ways that someone managed to do this would be very much appreciated.
Thank you.
