I am trying to correct a material issue in on of our Content Center Families. We have a Sheet/Plate family and one of the materials that we use is Diamond Plating as shown below.
Content Center
The problem is when a "Diamond Plate" part is placed into an assembly the material is not correct, it comes in as shown below in image 1 and the second image is how it should look. You can see that in both images the material is set to "Steel, Diamond Plate" but the appearance in the incorrect image is set to "Diamond Plate" and in the correct image it is set to "Diamond Plate 2...".
Wrong
Correct
If I go into Content Center Editor and look at a line in the family table that should be Diamond Plate I can see that the material is set to "Steel, Diamond Plate" but if I go into the Material Guide for that row it does not show "Steel, Diamond Plate" as an option to add or to delete.
Family Table
Material Guide
How do I correct the Material/Appearance for the diamond plate lines in this family?
