Constraints "exploding" on the other side of grounded parts.
moped4200dk
moped4200dk
Please fix Inventor so that it doesn't calculate and sometime "explode" constraints at the other side of grounded parts..
Here is an example of what I mean:
The parts by number 1 are, as I want is to be.
the parts by number 2 are grounded
I then change the length of pipe by number 3..
When I did that, the constraints "exploded" over by number one..
So the constraint error I made by number 3 somehow carries across grounded parts, even though they have no connection to the ones by number 1 except both sides are constrained to the grounded parts..
It is super annoying and very time consuming, that grounding parts doesn't mean that the parts on one side of the grounded parts not are safe from changes at the other side of the grounded parts..
JDMather
Can you zip and Attach your assembly that exhibits this behavior here.
I suspect a Screencast recording of the behavior might also be critical for diagnosing the issue.
johnsonshiue
Hi! The behaviors you described do not sound right to me. Something is off. Assembly constraints are bi-directional. It means that unless the component is grounded, the actual movement can happen to either constraint participant. If possible, please share the files here. I am more than happy to take a look and understand the issue better.
Many thanks!
Software Test Engineer
moped4200dk
Than you for your replies.
I don't know, if i can recreate the situation, but I will try, when I have a little spare time at the office.
And yeah, I understand that the constraints are bidirectional, but I don't understand, why Inventor not stops it calculations, when it reaches a grounded part.. Gounded parts can/may not move or rotate at all, so there is no need/reason to calculate what happens on the other side. But for some reason Inventor still waste processing power on calculating the entire part-chain, going through grounded parts. (I don't know, if it always do, but it clearly sometimes do, if it didn't, my constraints-errors shouldn't be able to make things on the other side of constrained part "explode" and give errors there).
johnsonshiue
Hi! Grounded components do not have DOF. As a result, their DOF is not solved. But, they still participate in solving since they are stationary reference to other components.
It is hard to tell if this is a bug or a limitation. If possible, please share the files that exhibit the behavior. Forum experts can take a look to understand the behavior better.
Many thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
