10:40 PM
Hey guys,
Apologies in advance if similar questions have already been asked. I'm very new to Inventor and to 3D modelling for that matter.
I've modelled a steel workbench (please the attached) using the frame generator. The bench top (3mm steel plate) was drawn as a part and inserted into the assembly. I have the following questions:
- When using the frame 'joining' options such as miter, trim to frame etc... does Inventor treat the frames that have been joined as welded sections (cannot move in relation to each other) or do I need to physically add the welds?
- When applying a 'mate constraint' (I mated the bench top to the bench frame) and giving it a certain offset limit, does Inventor treat the mate as welded/bolted or do I need to apply the welds/bolts?
- The bench will simply sit on top of a concrete slab/floor so which constraints do I need to use for the stress analysis? I tried to use 'frictionless constraint' at the base of the bench as to prevent the downward movement of the base when a force is applied to the bench top but Inventor is telling me there are not enough constraints! The stress simulation ran OK when I changed 'frictionless' to 'fixed' constraint. Why do I need a fixed constraint when a slight displacement of the frame legs is to be expected under extreme overloading? (please see the attached).
Thanks in advance for any inputs.
Pete
