Constraints between points in two different sketches
dzwick
dzwick
Hello guys! I am learning Inventor 2020 for hobby purposes, and since this is my first experience with CAD software, many things baffle me. At the moment, I am stuck on drawing a chip resistor. I have decided to make it a multibody part to be able to assign different materials to its terminals and body. So I drew two sketches on the XY plane, one for the terminals and one for the body. It is obvious that the body must be attached to the terminals. For this, I want to make some points on the body sketch coincide with the points on the terminals sketch. Here is the screenshot:
The C-shaped parts are the terminals (the first sketch), the rectangle between them is the body (the second sketch). How can I make the circled points to be coincident? Is it even possible to create constraints between different sketches?
JDMather
Yes, Project Geometry points from first sketch into second sketch.
(See Attached.)
dzwick
Thanks! It worked! For other newbies like me I want to add some clarifications. To Project Geometry points from sketch A (the resistor's leads in my case) to sketch B (the resistor's body) you should go to sketch B, click "Project Geometry", and then select points on sketch A. My mistake was that I tried to do this while I was editing sketch A. I was literally trying to project sketch points onto itself.
