Constraint to projected geometry
berry.lejeune
berry.lejeune
Something I noticed now already a couple of times in 2023. When i make a new sketch and I project lines on it from the geometry and I place an arc and I want to make this tangent to the projected line, I'm getting a  fault message
But when I break the link from the projected line, it lets me place the constraint.
Is there somewhere a setting what I can change because in 2020 I didn't have this issue. Especially if the geometry changes dimensions and the projected line doens't follow this anymore
JDMather
@berry.lejeune
Can you Attach file(s) here that exhibit this behavior?
berry.lejeune
@JDMather
I attached a file. It seems that I'm having this issues only with part templates that I made myself. When I try a template what comes with Inventor, all is ok
kacper.suchomski
Hi
I have no problems with it.
Check that you have the latest update (2023.2.1, I think).
I checked both edge and loop project.
Kacper Suchomski
Frederick_Law
No problem with tangent.  2023.2.1
I usually avoid project from the model.
Also avoid project whole face.
Just project edge I needed.
I'll project from the sketch that create the model and avoid "chain projection": project same thing from one sketch to next.
Just project from the first sketch the feature is created.
