How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
there is possibility to add constraint UCS to UCS. I'm wonder if is there some easy solution how to constraint two parts in assembly to by their global coordinate system.
I'm not talking about Place grounded to origin. I need to constraint two parts in an assembly to each other by their coordinate systems, but keep them free (stick together, naturally) in the assembly.
There are these "workarounds":
Thanks for your replies.
@j.pavlicek I think this is what you are after - (Creates three flush constraints to the origins).
Hi! Another workflow to consider is to use UCS. You can constraint two UCS' by using Constraint Set. Just select the UCS from each component, the two will be snapped based on the UCS.
Many thanks!
Then there's the basic manual method: Mate/Flush constraints XY-XY, YZ-YZ, and XZ-XZ. That's essentially what the tool does that @gcoombridge recommends.
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
How to buy
Type a product name
