constraint issues Inventor 2025
tom
tom
Big issue with Inventor 2025:
When you edit a part in inventor 2025 it seems that the constraints aren't working annymore. Like when you edit the length os a collumn the endplate, that is fully constrainted to the collumn, will stick at it's orriginal position. But if you edit the constraint that fixes the plate at the end of the collumn, the plate will move. This is bloody annoyning and dangerous.
See attachements:
C1: the collumn
C2: the constraint
C3: orriginal length of tube
C4 (next message): length changed from 1000mm to 800mm
C5 (next message): return to assembly and plate still in orriginal position
C6 (next message): edit constraint with tube
C7: (next next message): plate again fixed on tube.
Kind of strange issue.
tom
Next attachements
tom
Next next attachements
tom
rebooted inventor and the issue was solved by itself, weird but it's solved. Thread maty be closed.
