Constraint folders
Constraint folders
chriseason_ce3
Constraint folders
chriseason_ce3
Community Visitor
Community Visitor
You can add parts to sub folders in the model tree but you can't add constraints to sub folders either under the part drop down or the assembly relations folder. This makes it cumbersome to find existing constraints for edit in complex assemblies. Is it possible to allow constrains to be added to model tree sub-folders?
James_Willo
Sorry this is not possible but you can post it to the ideastation if you want.
If you click a component and press ctrl+b it will find it in the browser so it's slightly easier to find the mate attached to it.
James W
Inventor UX Designer
