Constraint error visibility
patrickDR4X5
patrickDR4X5
Long-time SW user transitioning to Inventor, one of the things I have noticed is that when working in an assembly, when a constraint or frame modifier (like corner joint or trim/extend) has an error, the error icons are often buried in the component tree and it can be difficult to find which components have errors.
For example, in the attached photo I have a frame with several members that have errors in the trim/extend feature, however I had to click through each individual member to determine which ones had issues. In SW typically there is a higher-level icon or list of all mates that you can view to ensure there are no errors.
Does inventor have a way to summarize/identify the errors or am I stuck hunting these down?
CCarreiras
Hi!
Check if you have a red cross... it will show you all the issues in the models, and you can pick one by one to fix it:
CCarreiras
