Constraining tangent point of a circle in assembly
Hi, I am trying to use a tangent point (not the center point) of a circle as a pivot point (marked image) to constraint the component at 15° angle in assembly. I have tried to do it with Angle Constraint, Explicit Reference Vector commands, however it used the center point as the pivot point. Please find the attached iam file.
The result I'm expecting is like this:
Which commands should I use, and how? Your help is greatly appreciated.
Lanette
blair
The IAM file is a database of which IPT files are required and it contains their position and constraints.
That being said, I would probably constrain the shaft using it's Axis to get the correct angle and then constrain the Point to the plate surface unless you require the shaft to pivot around the point. This will still leave the shaft to pivot around the Work Point while maintaining the angle. It will still have a couple degrees of freedom that would require additional constraints.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Hi blair, thanks for your reply. I have constraint the shaft to the right angle and added a work point at the tangent point. How do I constraint the point to the plate? Please find the attached files. (including ipt file)
blair
 I don't see a Work Point placed on your PC CSK rattan screw. You would need to have the Work Point on your IPT file part. It looks like you placed the work point in the IAM file.
Delta Tau Chi ΔΤΧ
