Constraining multiple parts to the same plane in assembly
Message 1 of 14
I am trying to constrain multiple parts to the base plane in an assembly.  I cannot figure out how to select multiple faces and have them all be constrained the same plane at once.  It would save me a lot of time if I was able to do this instead of selecting each face individually.
Thanks for your time
Replies (13)
Message 2 of 14
cbenner
Unfortunately that is not the way that Inventor works.  Each part will need it's own individual constraints, one face at a time.  It's better this way... would you rather have one constraint fail, or several at the same time?
Message 3 of 14
Curtis_Waguespack
Hi jvb17,
Is it always the same plane in the components that you want to constrain?
I think I have an ilogic example that constrains panels (all with the bottom of the part on the XY plane) using the XY plane of each part to the XY of the assembly, would something like that work for you?
Or are the plane/faces of each part different?
I hope this helps.
Curtis
Message 4 of 14
That's exactly it!! I would very much appreciate that! I have not used iLogic yet.
Message 5 of 14
Curtis_Waguespack
Hi jvb17,
Here's an iLogic rule to place a Flush Constraint between every component and the assembly XY plane, and a quick video showing how to put it in place.
Post back if you have questions.
I hope this helps.
Curtis
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPlane As WorkPlane
Dim oProxyPlane As WorkPlaneProxy
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	'check for and skip virtual components
	'(in case a virtual component trips things up)
	If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
    	oPlane = oOccurrence.Definition.WorkPlanes.Item(3) 'XY plane
		'create component proxy plane in assembly
   		Call oOccurrence.CreateGeometryProxy(oPlane, oProxyPlane)
	'get assembly plane
	Dim oPlane2 As WorkPlane
	oPlane2 = oAsmCompDef.WorkPlanes.Item(3) 'XY plane
	' Create the constraint using the work plane proxies.
    Call oAsmCompDef.Constraints.AddFlushConstraint(oProxyPlane, oPlane2, 0)
Next
Message 6 of 14
Wow, really appreciate this!!  I'll get back to you when I use it at work tomorrow!
Message 7 of 14
Curtis_Waguespack
Hi jvb17,
Here's a quick modification that deletes existing constraints of a certain name, and then re-applies them.  This allows you to add more panels, and use the rule again, without creating duplicate constraints.
I hope this helps.
Curtis
'Delete Existing Constraints named XY_Flush...
Dim oConstraint As AssemblyConstraint
	For Each oConstraint In oAsmCompDef.Constraints
	If oConstraint.Name.Contains("XY_Flush") Then
		oConstraint.Delete
Next
i = 1
	'get assembly plane
    oConstraint =  oAsmCompDef.Constraints.AddFlushConstraint(oProxyPlane, oPlane2, 0)
	oConstraint.Name = "XY_Flush:" & i
	i=i+1
Next
Message 8 of 14
kadscad
I can't believe this not an option. yes, I know it could be dangerous. Who doesn't enjoy a little danger?
Kirk
Inventor 2023
Message 9 of 14
IgorMir
No need for a little danger here. Using Muscular Modeling technique allows user to place most of the component into an assembly - grounded. Because the individual components share the same Origin Planes.
Cheers,
Igor.
Web: www.meqc.com.au
Message 10 of 14
Mark.Hynd
Hi Curtis,
Is it possible to run the same rule but instead of a "Flush" constraint apply an "Angle" constraint between the same XY planes?
Thank you!
Message 11 of 14
Curtis_Waguespack
Hi @Mark.Hynd
See this example. I'm not sure if this is exactly what you are looking for, but it does place an angle rather than a flush
I hope this helps.
Curtis
'oAngle = 15 'angle in degrees
oAngle = InputBox("Enter angle", "iLogic", 0)
If oAngle Is Nothing Then Exit Sub
If IsNumeric(oAngle) = False Then Exit Sub
oConstraintName = "XY_Angle"
	If oConstraint.Name.Contains(oConstraintName) Then
		oConstraint.Delete
Next
i = 1
	'get assembly plane
	oConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oProxyPlane, oPlane2, oAngle * 180 / PI,
	AngleConstraintSolutionTypeEnum.kReferenceVectorSolution, oAsmCompDef.WorkAxes.Item("X Axis"))
	'optionaly you could use this line and NOT specify an rotation vector
	'oConstraint = oAsmCompDef.Constraints.AddAngleConstraint(oProxyPlane, oPlane2, oAngle * 180 / PI)
	oConstraint.Name = oConstraintName & i
	i = i + 1
Next
Message 12 of 14
Mark.Hynd
I'll be sure to try this next week! Thank you very much for the active help!!
Message 13 of 14
kkryzerDDLSP
Community Visitor
Community Visitor
Is there a way to use this method without constraining ALL of the parts in assembly?  Could I do it just to a select group of objects so my entire assembly doesn't come apart?
Message 14 of 14
johnsonshiue
Hi! You may demote the components into a subassembly. The entire subassembly move together.
Many thanks!
Software Test Engineer
