Cone flat pattern
Cone flat pattern
codyLEPBA
Message 1 of 8
Cone flat pattern
codyLEPBA
Hi guys, so we are working with Aluminum 3003 H-14, and I am trying to get Inventor to create a flat pattern for a cone, but I am having problems getting it to calculate the correct flat pattern from the folded model. Would this be a material type issue or would this be a sheet metal bend rule issue? I am a little unsure of how to track this down to get it to work properly. Any advice is appreciated. thanks
Replies (7)
Message 2 of 8
CGBenner
@codyLEPBA
Welcome to the forum!
Would it be possible to share a file here so others can see what you have tried so far, and offer suggestions?
Chris Benner
Message 3 of 8
Frederick_Law
Change k-factor until you get correct flat.
It depends on how the cone is formed and material.
Are you rolling or bumping the cone?
Message 4 of 8
codyLEPBA
We are rolling it, when I create this flat pattern both the material and K-factor will affect the outcome right?
Message 5 of 8
codyLEPBA
Hi and thanks, I have read a ton of these posts over the years this is my first time asking though. I have attached my .ipt file for you to take a look at. if you need anything else please let me know
Message 6 of 8
Frederick_Law
For rolling, start with k=0.5.
Adjust with test.
You'll need extra material on both end to roll and cut to size after.
Message 7 of 8
codyLEPBA
thanks, how important is it that my material properties are perfect? I was trying to input them but I am not entirely sure I got them correct as I had to do several unit conversions to get it to the units that Inventor uses
Message 8 of 8
Frederick_Law
Material in CAD doesn't matter.
Material used in rolling will change k-factor.  Hardness, strength, temperature will affect how the material compress and stretch.  Usually not much but it depends on how accurate you need.
Then, it's not machining.  So within 1/16" is enough.
