Computer Shuts off During Rendering
This widget could not be displayed.
Hi guys,
For the last little while, I've been rendering (sometimes simple, sometimes complex) parts and assemblies. I've rendered some of these assemblies previously without any issues, but now my CPU maxes out and the computer shuts down.
Any idea what could be going on?
Cheers
mdavis22569
Can you share your PC specs?
CPU / RAM / GPU?
Mike Davis
CPU: Intel Core i7-7700HQ @2.80GHz
RAM: 16GB
GPU: NVIDIA GeForce GTX 1050 Ti
I should add that I noticed my CPU maxing out at 100% and the computer shutting down after a certain time. I resorted to cutting down my maximum CPU speed to 90% and the issue hasn't come back but renderings are much slower.
mdavis22569
What driver are you using?
I would try the following:
https://www.nvidia.com/download/driverResults.aspx/126179/en-us
Is this a large assembly?
I would keep it lower ... never want to max anything out ..
Mike Davis
I'm downloading the driver now and will give it a shot. Not very large, I've rendered much bigger.
DarrenP
this is more of a computer issue than inventor
most likely your computer is overheating
check the temps of cpu & check all internal fans, blow out any dust that may be inside the computer
DarrenP
