Message 1 of 10
Compression spring Drawing
Hello guys,
- I am trying to design a spring. After filling in all the parameters and performing the calculation, everything looks fine. The spring will generate fine as well.
- The problem arises, when I want to make a drawing. The dimensions, specifically the pitch, do not fit.
Where did I go wrong? - Parameters are (according to the accelerator table to) the pitch should be 5mm, the wire diameter 1mm, the length 17.25 and the outer diameter 24. Active coils 3.
But the pitch in the drawing is 7.29.
I am attaching a photo of the drawing and table from the accelerator.
Thanks for any sugestions.
