components on Sketch Points for array in assembly
didier.spinnewyn
didier.spinnewyn
hello,
as in the parts, do components on Sketch Points for array in assembly.
CCarreiras
Hi!
No.
But, if in this case you already have the point array in a part, you can use it in the assembly, using this option:
CCarreiras
SharkDesign
Do you mean, you want this feature considering for future?
As in this for an assembly
Post it in the ideas forum.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
I think it doesn't work because sketches aren't very good in the assembly environment and can break very easily when geometry changes.
  Inventor Certified Professional
didier.spinnewyn
Yes, I just tried. in my part I made a sketck driven with an axis and I got the function in the assembly to create my array.
