Hi I'm having an issue with some assemblies. The component replace option is missing from the drop down list when I click on it!
Does anyone know how to solve this issue?
I'm using Inventor Professional 2021.
Solved by mcgyvr. Go to Solution.
Is that missing for all weldment assemblies?
I don't use them but it could be that component replace isn't something you can do with weldments.. Components inside a weldment yes but the weldment itself no..
@Francis.Foley wrote:
Both items are weldment assemblies.
@Francis.Foley The second image you posted isn't showing you clicking on a weldment.. Thats a sheet metal part inside a weldment..
I see my error, I opened the incorrect assembly. I was trying to replace an assembly in sub assembly of the main assembly.
All I need to so was open the sub assembly and replace the assembly in that.
Sorted thanks.
