Component Pattern
Component Pattern
DavidTunnard
Component Pattern
DavidTunnard
Is there a way to create a pattern in an assembly and specify that you want to use 'distance' instead of 'spacing'. You can do this within a part file, so not sure why the dialog box is not the same?
Assembly Pattern BoxAssembly Pattern Box
Part Pattern BoxPart Pattern Box
IgorMir
I think you can achieve it by using some formulas.
You see - the module for parts and the module for assemblies were designed by different people. That's why the interface for seemingly similar action is different in its functionality. The user of Inventor has to be aware of it. And stay alerted.
Web: www.meqc.com.au
bhavik4244
@DavidTunnard
You may do it with two other way since, distance option might not avauilable for components pattern.
1. By adding distance and divided by the number of qty which eventually termed as spacing, but you may enter the distance itself.
2. Another would be to make a sketch pattern.
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/da14dded-ad0d-4ff9-a331-ee...
I would also look for any other way to do this from any experts here.
Bhavik Suthar
JDMather
Depending on your Design Intent - it might make logical sense to create your Component Pattern in >>this way<<.
CGBenner
@DavidTunnard
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
