I am trying to figure out what Inventor is doing. If it is writing files, where is it putting them. If it is still putting everything into RAM, some clue about how much longer the process will run -or if I can interrupt it, but save the progress so I don't start from scratch all over again. Maybe some way to peek into the 3.2GB step file which contains thousands of pieces, and somehow extract it by groups of pieces at a time.
My goal is to open the complex assembly provided by my customer so I can use Inventor to calculate the mass moment of inertia. My problem is that after 5 hours, the file import or conversion bar is only at 95%, and has been at 95% for 4 hours. The CPU is still running at 25%, RAM use is up to 54GB out of 128GB. Inventor and task manager are the only programs I have opened.
My machine has a Xeon E5 processor with 8 cores rated at 3.6GHz, and 128 GB of RAM.
The 3.2 GB step file is on the local hard drive.
This machine runs Autodesk Inventor 2016, OS is Windows 7
Last night, I had the same experience with my Windows 10 "workstation Laptop" with it's middling i7 processor and only 16GB RAM. After three hours Windows warned insufficient RAM was left, so I did File:Save and made an unholy exit from Inventor. I found 2,713 component files totaling 3.5 GB on my hard drive. All nuts and bolts and tubing, no assembly file.
I began importing the file on the Xeon workstation today at 9:59 AM, by 10:20 AM the screen came up asking if I want to convert the file. Prior to that, the Inventor screen communicated nothing other than a little blue spinning wheel. No image was shown, no indication a file had been imported. I selected convert and CPU usage jumped from 25% with only four cores running (one was doing most of the work) to 100% usage of all 8 cores. By 10:54 AM the progress bar was at 95%.
Since that time RAM usage has been increasing slowly. It was about 40 GB and now is at 53 GB, but CPU usage dropped to 25% and not all cores running after hitting the 95% mark. Back when it first hit 95% on the progress bar, I checked my resource monitor and saw the hard drive appeared to be very active ranging from 1 MB/sec to 10 MB/sec if I recall correctly. Drive activity now is down to 100 kB/sec.
The biggest files indicated on Windows resource monitor are in my user/appdata/temp directory and called MMF99DF.tmp and MMF99DE.tmp. They get up to as much as 700MB, then drop down to a smaller size such as less than 40MB and begin growing again. I don't know how to stop resource monitor from constantly shuffling the file order so it's hard to watch these change when they keep zipping off the screen. I'm guessing these tmp files are created and saved as something else, then start another file.
Sorry for the long post and probably lots of irrelevant info, but I am not a CAD expert, I am an engineer. Yesterday I had the good fortune of getting the moment of inertia data from a simpler assembly in just a matter of a few clicks. This more complex assembly is kicking the butt of my computer.
Again -any way I can get Inventor to stop at this point, write what's it's got out to the drive in iam or whatever extensions, and then maybe I can restart to just finish the rest? Annoying that it is stuck at 95% with no error message and still filing RAM and writing files somewhere, but not to the directory I chose.
