Compare Flat Pattern In Assembly?
xapex93586
xapex93586
Is there really no way to place flat patterns in assemblies so they can be compared?
Mario.VanWiechen
Use "Unfold " command on the part and bring it into the assy that way.
OR derive the part, unfold that and then you can compare in the assembly
BDCollett
If you are on 2022 or above, create a new model state, unfold and then use that in the assembly.
johnsonshiue
Hi! Or, export the flat patterns as STEP files. Then import them back to the assembly.
Many thanks!
Software Test Engineer
