Hi!
After updating Inventor from 2020 to 2024 I'm experiencing slow response when doing commands such as "measure" or "constraints".
For example when I want to measure something in an assembly, I right click and pick "measure" (or just click M on the keyboard) it takes up to 20-30 seconds before the measure window pops up and I can start measuring. When the window first appears I can measure as normal. The same goes for commands such as constraints, free rotate etc.
It also seems that the delay mostly applies to the initial measure/command, and that consecutive commands (in the same assembly) has no delays.
However when opening another assembly or another assembly-level, the delay is back.
The response is also initially slow when switching between assembly-levels or to part-level. When I have first gone from assembly-level to an individual part once, doing the same with other parts there is no delay.
- Settings are migrated from 2020
- Checking parts/assemblies/drawings in and out from Vault 2024 works just fine
- Inventor 2020 is uninstalled
- During the delay Inventor has a "not responding" status until the command window pops up
