Combine Similar Hole Count on single drawing view
0x3FA5
0x3FA5
The holes were added on assembly level, a few holes under every "Hole" feature.
Most of them are the same size:
Although most of them are the same size and depth, on the drawing they are not combined.
For example, this hole count on the model is approx 60, but the callout shows only 6:
How do I combine all similar holes qty on one view?
Thank you.
blandb
In the hole callout, what option do you have set for the "Edit Quantity Note". Is it set to Number of Holes in pattern or feature:
or Number of Like Holes in view (Normal):
If set to pattern, then change it to be "like holes in view". Does that fix your problem?
Autodesk Certified Professional
0x3FA5
Ha, It worked, many thanks!
