The analyze interference function generates a report table, that when printed, clips the text in columns where text extends very wide.
How can I resize the column so that the wider columns do not get clipped when the report table is printed?
The dialog window, with the interference fit table, is not resizeable and changing the width of the column in the table has no affect on what gets printed out.
Solved by Curtis_Waguespack. Go to Solution.
Hi Lhann,
The button next to the Print button will Copy the table information to you clipboard. Then you can open and new spreadsheet and Paste in the table information. From there you can arrange the columns and set up the print area as needed.
I hope this helps.
Curtis
Hi Lhann,
I hope this helps.
Curtis
