collisions in the assembly
Good afternoon. Tell me what is the fastest way at the intersection of two parts to create in the place the intersection of hole parts so that there are no collisions in the assembly
Добрый день. Подскажите каким наиболее быстрым способом на пересечении двух деталей создать в месте пересечение деталей отверстий , что бы не было коллизий в сборке
JDMather
What version of Inventor?
Can you Attach your assembly here?
Autodesk AutoCAD 2017 Certified Professional
You can do without additional sketch constructions ?
JDMather
I have only Windows OS zip, no rar extractor.
reloaded
JDMather
I don't have Inventor 2017 (you should install the Updates for 2017), so I will have to type out description of steps.
In assembly Shift Right Click and select Part Priority filter.
Right click on the sheet metal part and select Edit (not Open).
Start a new sketch on the face of the sheet metal part (or the XY Plane of the part).
Project Geometry a circular edge of the pipes.
You can offset circles for clearance and then Extrude-Cut.
Alternatively,
You could edit the part as above but then
Modify>Copy Object and copy face of pipes into sheet metal part to use to Split or Sculpt the holes.
With either of these techniques - if you move the pipes, the hole positions will automatically update.
Edit:  I just noticed that you used the same sheet metal part on the other side.
This presents a problem.
I would Derive Component the sheet metal part and use the original un-cut on the one side and then the Derived Component on the side to be cut. Then as above.
