I am trying to make an engraving into this cylinder for a cam follower that is 6.5mm in diameter so I need it to be 6.5mm wide at all parts so that the follower fits snuggly. How would I do this. I made the sketch on the side of the cylinder and then coiled it around a work axis in the middle of the cylinder.
I can share more screenshots and info if that is needed. ( three screenshots attached )
Thank you in advance!
