Clerence fit check
Clerence fit check
baliasM74U3
Clerence fit check
baliasM74U3
Hi Experts
INV 2020
Is there any option in inventor to check the clerence fit of two components in an assembly ?
To see how much tolerences are required to make the parts assembly properly ?
Or is there any place/texts where i can find these guidelines ?
Curtis_Waguespack
Hi @baliasM74U3
You can set the tolerance of the dimensions within the model.
For instance when creating a hole feature you can click the arrow in the diameter input and choose Tolerance, or you can do it through the parameters dialog
or you can set the tolerance when adding a dimension in a sketch
And there are these tools as well:
Calculate limits and fits | Inventor 2022 | Autodesk Knowledge Network
Tolerance Analysis Overview | Inventor 2020 | Autodesk Knowledge Network
I hope this helps.
Curtis http://inventortrenches.blogspot.com
johnsonshiue
Hi! Another option is to do one-directional tolerance analysis using Inventor Tolerance Analysis tool.
https://www.autodesk.com/products/inventor-tolerance-analysis/overview
Many thanks!
Software Test Engineer
