Choose columns in BOM not working
Message 1 of 8
I'm having a problem with 2021, in that I can't add a new column to the BOM, any one having this problem?
Replies (7)
Message 2 of 8
SBix26
Not having this problem.  Can you describe your problem with more detail, or provide a screencast of the process?
Sam B
Inventor Pro 2021.0.1 | Windows 10 Home 1903
LinkedIn
Message 3 of 8
johnsonshiue
Hi! I cannot reproduce it either. Please share a screenshot of what you are seeing. 2021.1 update will be live soon. Please install it when available.
Many thanks!
Software Test Engineer
Message 4 of 8
The first issue of the @'choose column' is resolved, that is an issue of using multi-screens, if the BOM table is on another screen & the 'Choose column' is selected the column doesn't appear, the BOM table must be placed on the main screen for the column to appear.
The next issue i have with the BOM table in 2021 is that the structure tab doesn't display 'all levels' see attached screenshot. Also I'm still on version 2021.0, i haven't installed .1 yet.
Message 5 of 8
CGBenner
It looks like the levels are there, you just need to expand them?  It will not do this automatically.
Chris Benner
Message 6 of 8
wbiskay
thank you for the answer for the column choser
walter biskay
Message 7 of 8
dave_oliver
Replying to old post:
I often move the BOM window to my 2nd monitor, have never had a problem on either monitor until recently.
Now I have been having the same issue, the BOM 'Choose Column' function would not work.
I managed to sort it using Gary's tip. I moved just the BOM window to my main monitor, but still no luck.
I closed the BOM window, moved the whole Inventor session to the main monitor, re-opened the BOM window and it worked.
Inventor needs to be on main monitor for BOM 'Choose Columns' function to work.
Thanks Gary.
Message 8 of 8
dave_oliver
Retraction:
My apologies, Inventor session does not need to be on the main screen for BOM 'Choose Columns' to work, just the BOM window.
