Inventor Forum
Children with model states display error
12 REPLIES 12
Message 1 of 13
ryan.d.amundson
556 Views, 12 Replies
I have an assembly which consists of several parts with a selected model state (not master).  When the assembly is saved, closed, and re-opened, the Model Tree indicates the correct model state but the parts do not display the correct model state in the assembly.  There is no option to update the assembly, but a rebuild all forces the parts to display correctly.  The problem then repeats itself when the assembly is saved and re-opened.
12 REPLIES 12
Message 2 of 13
Hi! This does look like a bug to me. Somehow the Model State member doc is not properly created and the graphics is not properly updated. I had to open each part, activate each Model State, and save. After that, the Model States are in sync again. Please take a look at attached file.
Many thanks!
Software Test Engineer
Message 3 of 13
@johnsonshiue
updating an individual part manually seems to retain the proper geometry after a save, close, re-open. updating all children via API will break the assembly again. (i didnt verify using API on only a single child.) the macro seems to revert each child differently to some other state.  below is the VBA code used to execute the updates if that will help.
the macro was created as a proof of concept. we intend to package the functionality into an add-in. the basic premise is to add or update all model states of the child files based on the three input values. some of the CLR child files may have model states just to activate, others will need them created.
Sub CLR_ModelStates()
    'Verify Assembly is active
    If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
        MsgBox ("An assembly must be active")
    Else
        'Define Variables
        Dim Front_Overhang As String
        Dim Truck_Centers As String
        Dim Rear_Overhang As String
        Dim oOccA As ComponentOccurrence
        Dim oMSFactoryA As PartDocument
        Dim oAsmParam As Inventor.Parameter
        Dim Front_Overhang_Param As UserParameter
        Dim Truck_Centers_Param As UserParameter
        Dim Rear_Overhang_Param As UserParameter
        Dim oDocA As AssemblyDocument: Set oDocA = ThisApplication.ActiveDocument
        Dim Front_Overhang_Exists As Boolean: Front_Overhang_Exists = False
        Dim Truck_Centers_Exists As Boolean: Truck_Centers_Exists = False
        Dim Rear_Overhang_Exists As Boolean: Rear_Overhang_Exists = False
        'See if CLR parameters exist and if they do set their values in the form
        For Each oAsmParam In oDocA.ComponentDefinition.Parameters.UserParameters
            If oAsmParam.Name = "Front_Overhang" Then
               Front_Overhang_Exists = True
               Set Front_Overhang_Param = oAsmParam
               FO_Array = Split(oAsmParam.Expression, " ")
               CLR_ModelStates_Form.FOTextBox = FO_Array(0)
               CLR_ModelStates_Form.UnitComboBox1.Value = FO_Array(1)
            If oAsmParam.Name = "Truck_Centers" Then
               Truck_Centers_Exists = True
               Set Truck_Centers_Param = oAsmParam
               TC_Array = Split(oAsmParam.Expression, " ")
               CLR_ModelStates_Form.TCTextBox = TC_Array(0)
               CLR_ModelStates_Form.UnitComboBox2.Value = TC_Array(1)
            If oAsmParam.Name = "Rear_Overhang" Then
               Rear_Overhang_Exists = True
               Set Rear_Overhang_Param = oAsmParam
               RO_Array = Split(oAsmParam.Expression, " ")
               CLR_ModelStates_Form.ROTextBox = RO_Array(0)
               CLR_ModelStates_Form.UnitComboBox3.Value = RO_Array(1)
        Next
        'If parameters do not exist create them and set their values in the form
        If Front_Overhang_Exists = False Then
            Set Front_Overhang_Param = oDocA.ComponentDefinition.Parameters.UserParameters.AddByExpression("Front_Overhang", "0", "in")
            CLR_ModelStates_Form.FOTextBox.Value = "0"
            CLR_ModelStates_Form.UnitComboBox1.Value = "in"
        If Truck_Centers_Exists = False Then
            Set Truck_Centers_Param = oDocA.ComponentDefinition.Parameters.UserParameters.AddByExpression("Truck_Centers", "0", "in")
            CLR_ModelStates_Form.TCTextBox.Value = "0"
            CLR_ModelStates_Form.UnitComboBox2.Value = "in"
        If Rear_Overhang_Exists = False Then
            Set Rear_Overhang_Param = oDocA.ComponentDefinition.Parameters.UserParameters.AddByExpression("Rear_Overhang", "0", "in")
            CLR_ModelStates_Form.ROTextBox.Value = "0"
            CLR_ModelStates_Form.UnitComboBox3.Value = "in"
        'Show form
        CLR_ModelStates_Form.Show
        'Exit macro if canceled
        If CLR_ModelStates_Form.FormCancelled = True Then
            MsgBox ("You stopped the macro")
            CLR_ModelStates_Form.FormCancelled = False
            Exit Sub
        'Get form values and set assembly parameters
        Front_Overhang = CLR_ModelStates_Form.FOTextBox + " " + CLR_ModelStates_Form.UnitComboBox1
        Front_Overhang_Param.Expression = Front_Overhang
        Truck_Centers = CLR_ModelStates_Form.TCTextBox + " " + CLR_ModelStates_Form.UnitComboBox2
        Truck_Centers_Param.Expression = Truck_Centers
        Rear_Overhang = CLR_ModelStates_Form.ROTextBox + " " + CLR_ModelStates_Form.UnitComboBox3
        Rear_Overhang_Param.Expression = Rear_Overhang
        'Define new name using values from form
        Dim oName As String: oName = Front_Overhang + "-" + Truck_Centers + "-" + Rear_Overhang
        'Loop through all occurances and if it is a CLR ipt then create or update modelstates
        For Each oOccA In oDocA.ComponentDefinition.Occurrences
            If oOccA.DefinitionDocumentType = kPartDocumentObject And Left(oOccA.Name, 3) = "CLR" Then
                    'Check need to Create new modelstates
                    If CreateModelstates(oOccA, oName) = False Then
                    Set oMSFactoryA = oOccA.Definition.FactoryDocument
                        'Update Parameters for new modelstates
                        Call ChangeParameters(oMSFactoryA, Front_Overhang, Truck_Centers, Rear_Overhang)
        Next
        'Rebuild all of the files, save and Great Success!!!
        oDocA.Update
        oDocA.Save
        MsgBox ("Great Success!!!")
End Sub
Function CreateModelstates(oOcc As ComponentOccurrence, oName1 As String) As Boolean
'This function checks to see if the requested modelstate exists and if it does not it creates it
    Dim oPDef As PartComponentDefinition: Set oPDef = oOcc.Definition
    'See how many model states there are
     If oPDef.ModelStates.Count > 1 Then
        'Create additional model state
        Dim oMSFactory As PartDocument: Set oMSFactory = oOcc.Definition.FactoryDocument
        Dim mstate As ModelState
        Dim mstateexists As Boolean: mstateexists = False
        'Check to see if requested modelstate exists
        For Each mstate In oMSFactory.ComponentDefinition.ModelStates
            'If the modelstate exists activate the modelstate, exit function, and return True
            If mstate.Name = oName1 Then
                CreateModelstates = True
                oOcc.ActiveModelState = oName1
                Exit Function
        Next
        'If the modelstate does not exist create it and activate it
        If mstateexists = False Then
             oMSFactory.ComponentDefinition.ModelStates.Add (oName1)
        oOcc.Definition.Document.Save
    Else
        'Create first model state
        oPDef.ModelStates.Add (oName1)
End Function
Sub ChangeParameters(oMSFactoryA1 As PartDocument, Front_Overhang1 As String, Truck_Centers1 As String, Rear_Overhang1 As String)
'This sub changes the parameters of Front_Overhang, Truck_Centers, and Rear_Overhang in the requested part factory
    Dim oParam As Inventor.Parameter
    For Each oParam In oMSFactoryA1.ComponentDefinition.Parameters.UserParameters
        If oParam.Name = "Front_Overhang" Then
            oParam.Expression = Front_Overhang1
        If oParam.Name = "Truck_Centers" Then
            oParam.Expression = Truck_Centers1
        If oParam.Name = "Rear_Overhang" Then
            oParam.Expression = Rear_Overhang1
    Next
End Sub
Message 4 of 13
Hi! This has been reported as INVGEN-64026. Hopefully, it will be fixed soon.
Many thanks!
Message 5 of 13
EvanGu
in reply to: ryan.d.amundson
Hi! We are investigating this problem. The model state member document does not update correctly. Did you use API to edit the member document?
Evan Gu
Inventor/Fusion QA Engineer
Message 6 of 13
@EvanGu the VBA above is what is used to update the model states. The operations are performed on the occurrences inside the parent assembly rather than on the individual documents in their own context.
Steve Gunderson
CAD Coordinator - Loram Maintenance of Way
Message 7 of 13
EvanGu
in reply to: steven_t_gunderson
Hi Steven,
Thanks for the reply.
We resolved an issue that part file is not out of date if the member doc is edited by API, Ryan's data shows this problem, so I asked this question how he edited the data.
Evan Gu
Message 8 of 13
@EvanGu sorry if there was some confusion. I am the CAD coordinator at Loram working with Ryan to develop automation to update the model states of multiple children in an assembly. the above VBA code was written by Ryan and used to update the model states which produced the error.
Message 9 of 13
EvanGu
Hi Steven,
Thanks for the information. We fixed the member out of date issue in 2023.1, which should work for this case. Looks you created the data in 2022.2, do you have a chance to try 2023.1? or could you tell me the workflow, I'll try it.
Evan Gu
Message 10 of 13
EvanGu
@steven_t_gunderson@ryan.d.amundson do you have a chance to try it in 2023.1, it could be fixed.
Evan Gu
Message 11 of 13
steven_t_gunderson
in reply to: EvanGu
@EvanGu,
We are using 2022.2.2 company wide with a few people on 2022.3.1. I could install and verify in 2023.1 but that would not solve our problem. Is it not possible to complete the same fixes in 2022 and implement a similar patch?
Message 12 of 13
EvanGu
@steven_t_gunderson before porting back the fix to 2022, I just want to verify if the fix works for you, if it does work, I'll let the project team to do the same fix in 2022.
Evan Gu
Message 13 of 13
@EvanGu,
OK i will take some time to setup a test environment and verify. It'll probably be a day or two but i will post results here when I finish. Thanks for taking a look into it.
