Checking Constraint health in ilogic
Thomas.Long
Thomas.Long
I have a program with a dynamic assembly that either checks for pre existing parts and inserts them in, or else inserts a dynamic part, feeds it the geometry necessary, and then saves it as a new part and reinserts the new part. The problem is some of the older parts were generated differently, meaning the faces on them are different from the faces on newer parts.
Until now I've been using a work around with regards to constraints, basically telling the program to check distances to see if they're breaking. I'm hoping that there is a more effective way to check the health status of constraints in an assembly, or possibly even have it fix the constraints on its own, though I think that might be much more difficult (sorry I'm very new at this). Could someone possibly help me with some code for constraint check? I'm not using the visual basic only code right now, I've just been using the built in inventor stuff.
Thank you all for your help.
Curtis_Waguespack
Hi Thomas.Long
You'll wan to use the HealthStatusEnums.
Here's a related link:
http://inventortrenches.blogspot.com/2013/01/ilogic-delete-all-sick-assembly.html
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
HealthStatusEnum Enumerator
Description
Constants signifying the state of the Object.
Methods
Name Value Description
kBeyondStopNodeHealth 11785 Object is beyond stop node in the browser.
kCannotComputeHealth 11783 Object cannot be evaluated.
kDeletedHealth 11782 Object has been destroyed. You may be holding on to an empty 'shell' of the Object.
kDriverLostHealth 11780 Object is driven by data from other Object(s), and one or more of them have been disconnected.
kInconsistentHealth 11786 Object is inconsistent with another object.
kInErrorHealth 11781 Object's internal state is in error.
kInvalidLimitsHealth 11789 Object has bad limits. e.g. max < min.
kJointDOFLockedHealth 11790 Object is locked Joint.
kNewlyAddedHealth 11788 Object is newly added or unsuppressed and has not been solved yet.
kOutOfDateHealth 11779 Object needs to be recomputed with respect to its 'driver(s)'.
kRedundantHealth 11787 Object's solution is redundant with another object.
kSuppressedHealth 11784 Object has been suppressed.
kUnknownHealth 11777 Object's status is not known.
kUpToDateHealth 11778 Object is up to date.
