Changing the Default Template
e_frissell
e_frissell
I was wondering if there's a way to change the default template that loads when you try to create a new part/assembly from this menu.
Default templates are set up in the application options and when selecting the new menu it loads all my templates but when selecting the dropdown carrot menu and creating a new part or assembly it just loads the Inventor default
Frederick_Law
Default templates are all named "Standard".
Rename or copy your most used template to "Standard".
I mostly just use one template.
Also some commands only use those templates, good idea to replace them with your's.
