changing text and dimension layer
ggtoutounji
ggtoutounji
How can I change a dimension or text layer in a drawing? Inventor 2015.
Thanks.
Mark.Lancaster
@ggtoutounji
All dimensions to a given layer or only certain ones?
All this information is controlled under Manage/Styles Editor..  Look at Objects Defaults that is link to your active standard.
Mark Lancaster
Cadmanto
What ever you can or need to do with layers is here.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Like other experts have already shown, if you want to change all dimensions, it is better do in Standards and Styles Editor. If you just want to change individual dimension, you can to go Annotate tab and look to the far right. There are two dropdown lists. Select a dimension of interest. You will see the current layer and current style. You can make local change there.
Many thanks!
Software Test Engineer
ggtoutounji
Thanks.
