Changing name of parameters to new language pack
jakub_brenkacz
Observer Observer
jakub_brenkacz
Observer
Observer
[Inventor 2021]
Is there a possibility to change standard parameter names (e.g., in sheet metal like thickness/bend radiuses) From the original language pack the part was created to another that is currently opened? Firstly I had Polish, now it's English.
Names of operations changed automatically into the new language
CCarreiras
Hi!
I believe not.
If you need the parameters in english, you have to redo the part from the english template.
CCarreiras
kacper.suchomski
Operation names are descriptive, so they may update (unless you give them a custom name).
Parameter names are binding, they are used to define dependencies, so the program respects them regardless of the application language.
Kacper Suchomski
