Changing Material and Finish in an Assembly - iLogic
GKPByDesign
GKPByDesign
Was wondering, if i open an assembly i can run a code to change a material and finish to something else.
Example:
I have a part that is Steel, Mild and Black and i want it to be Acrylic and White?
mcgyvr
yes thats entirely possible..
How will Inventor determine which part you want to change in that assembly?
iProperties.Material = "Acrylic"
iProperties.PartColor = "White"
Sergio.D.Suárez
Hi, A little late, put together this code and it served me. Previously I had made one that identified the occurrence and opened a selected file in false mode, but this type of code gave a problem if the created piece had not been saved (for example, a piece created in the frame generator not yet saved). This new code opens in context and makes the changes it is not necessary that the piece is saved
change appearance of part
Sub Main()
		'Change the appearance of part
		'The part may not be saved
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPart As ComponentOccurrence
Line1 :
'''Pick part occurrence
oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select Part")
	If oPart Is Nothing Then
		Exit Sub
	Else
	    Dim oAsset As Asset
        Dim oAsset_Array As New ArrayList
        For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
        oAsset_Array.Add(oAsset_Array_X.DisplayName)
        oAsset_Array.Sort()
        Next
	    'present the user with the list to choose from
        100:
        oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
        If oAsset_Array_Selected = "" Then GoTo 100 :
		Dim oDef As PartDocument
	    oDef = oPart.Definition.Document
	    Dim oRenderStyle As RenderStyle
        oRenderStyle = oDef.RenderStyles.Item(oAsset_Array_Selected)
	    oDef.ActiveRenderStyle = oRenderStyle
        iLogicVb.UpdateWhenDone = True
End Sub
change material of part
Sub Main()
    'Change the material of part
'The part may not be saved Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oPart As ComponentOccurrence Line1 : '''Pick part occurrence oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Seleccione Pieza") If oPart Is Nothing Then Exit Sub Else Dim oDef As PartDocument oDef = oPart.Definition.Document Dim oMaterialAssets As AssetsEnumerator oMaterialAssets = oDef.MaterialAssets Dim oAsset As Asset Dim oAsset_Array As New ArrayList For Each oAsset_Array_X In ThisApplication.ActiveMaterialLibrary.MaterialAssets oAsset_Array.Add(oAsset_Array_X.DisplayName) oAsset_Array.Sort() Next 'present the user with the list to choose from 100: oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES") If oAsset_Array_Selected = "" Then GoTo 100: oDef.ComponentDefinition.Material =oDef.Materials.Item(oAsset_Array_Selected ) iLogicVb.UpdateWhenDone = True End If End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GosponZ
Hi Sergio,
i tried first code for appearance and is working good, but material is not working. After i pick part it makes error. Would you please revisit code. I m running INV 2021 and soon i'll switch to inv 2022.
Thank you
SharkDesign
I found material to  be the easy bit, the appearance was a nightmare and only overrode the appearance instead of changing at part colour.
I asked a similar question here:
https://forums.autodesk.com/t5/inventor-customization/get-appearance-at-part-level-from-assembly/m-p...
  Inventor Certified Professional
Curtis_Waguespack
Hi @GosponZ
The previous code was written for use in an assembly and will error out if you use it in a part file... here is a version that works for both assembly and part files. I've included a similar version for setting appearances as well
I hope this helps.
Curtis
Dim oDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	oDoc = ThisApplication.ActiveDocument
Else
	oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, _
	"Select Part")
	If oPart IsNot Nothing Then
		oDoc = oPart.Definition.Document
	Else
		Return 'exit rule
Dim oList As New ArrayList
For Each oItem In ThisApplication.ActiveMaterialLibrary.MaterialAssets
	oList.Add(oItem.DisplayName)
	oList.Sort()
Next
oCurrent = oDoc.ComponentDefinition.Material.Name
oMaterial = InputListBox("Select One", oList, oCurrent, "iLogic", "List of Materials")
If oMaterial Is Nothing Then return
oDoc.ComponentDefinition.Material = oDoc.Materials.Item(oMaterial)
Else
	"Select Part")
	Else
		Return 'exit rule
For Each oItem In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
	oList.Sort()
Next
oCurrent = oDoc.ActiveRenderStyle.name
oAppearance = InputListBox("Select One", oList, oCurrent, "iLogic", "List of Appearances")
If oAppearance is Nothing then Return
oDoc.ActiveRenderStyle = oDoc.RenderStyles.Item(oAppearance)
GosponZ
Thank you it is working good
