I have 45 PCs running Autodesk Inventor 2011 in a student PC lab. We have since set up Vault Server and I need to change the location that these point at.
The files that I need to edit can be got to by:
1. Open Autodesk Inventor
2. Click “Pro”
3. Click “Options”
4. Click the “File” tab
5. I need to edit the following: Default templates, Design Data (Styles, etc) and Default Content Centre files.
6. The above three will be pointed to a server that has vault setup on it (\\vault\templates, etc).
Now to clarify, Inventor works, I do not need assistance activating it, and I do not need assistance with group policy to set up the install...
I need to be able to modify the above with group policy through either the registry (if possible) or some other method. I just need to change the above to point at \\servername\share.
Cheers,
Justin
