can someone explain to me how you can change the projection angle from 1st to 3rd in a engineering drawing please?
(I use Autocad inventor 2015)
thanks.
Solved by admaiora. Go to Solution.
Admaiora
You have to be in a drawing file in order to see drawing styles. The options you note are what you should expect to see in a model file.
Sam B
Inventor Pro 2023 | Windows 10 Home 21H2
