Changing Appearance (Color) in iParts
Message 1 of 19
I have an iPart with multiple members, which I would like to have each a different color (appearance). Is that possible? I have Inventor 2016. Thank you
Replies (18)
Message 2 of 19
Mark.Lancaster
@Anonymous
In the iPart table, create a new entry called color or something on the Other tab.  Right mouse click on that column in the table and select Appearance.  Then fill in the cell values as the correct appearance name.
Mark Lancaster
Message 3 of 19
Thank you for your response.
How do I create the new entry in the iPart table? I try right clicking, and also can't find any "New" buttons or ICON's, so I don't know where to start. Sorry
Message 4 of 19
Mark.Lancaster
@Anonymous
Did you actually read my first sentence?  Add using the "Other" tab..  Smiley Wink
Mark Lancaster
Message 5 of 19
I apologize. I clicked on the folder, not the tab. My mistake. With your help, I have been able to accomplish what I requested. Thank you
Message 6 of 19
mark.martinezECRPT
Can you use this to change a specific body color if you have a multi-body part?
Message 7 of 19
johnsonshiue
Hi Mark,
I have replied to you on the other thread. https://forums.autodesk.com/t5/inventor-forum/change-body-s-appearance-in-ipart-table/td-p/10010946
Please take a look. Many thanks!
Software Test Engineer
Message 8 of 19
ToddPig
Mark,
Could you explain how you to add the appearances to the color column?
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Message 9 of 19
johnsonshiue
Hi Todd,
Mark is no longer with us. I am answering on behalf of him. To add a Color column, go to Other tab and add a property. Once the column is added, right-click on the header -> check "Appearance Column."
Many thanks!
Message 10 of 19
ToddPig
I got that far with Mark's instructions, but I can seem to get this column to provide any value???
I tried enter colors - no good
I tried entering appearance names - no good
I switch to Solidworks, and used configurations - GREAT!
Inventor 2018
iParts = iHeadache
Message 11 of 19
johnsonshiue
Hi Todd,
Yes, SWX is awesome. Everything is great! Simply bug-free and no workarounds required.
To add appearance to the table, you need to type in the exact appearance style name, like "Violet." The style has to be available in the active Appearance Library. Please share an example if it still does not work.
Many thanks!
Message 12 of 19
ToddPig
file attached
Inventor 2018
iParts = iHeadache
Message 13 of 19
johnsonshiue
Hi Todd,
Many thanks for sharing the part! The issue here is that Extrusion1 feature also has appearance override. The priority of appearance override is Face -> Feature -> Body -> Whole Part. Feature appearance overrides the Whole Part appearance. Simply right-click on the feature -> Properties -> Feature Appearance -> As Body. Then it will work.
Message 14 of 19
ToddPig
Still doesn't work.
Updated file attached.
Inventor 2018
iParts = iHeadache
Message 15 of 19
johnsonshiue
Hi Todd,
Sorry, I forgot to mention that you also need to clear out the Body color override. This iPart has multiple color overrides starting from feature, body, and then the whole part. You need to clear out feature and body color overrides. Right-click on the solid body -> Properties -> Appearance Override -> As Part.
Another way to do it is to use the Clear Override button (the color wheel with a checkmark) to blow away all color overrides.
Many thanks!
Message 16 of 19
Bhargav_PatelTYWUT
Community Visitor
Community Visitor
Is it possible for us to have the same thing for an individual feature?
Message 17 of 19
CGBenner
@Bhargav_PatelTYWUT
Hi, are you asking about changing the color of a specific feature in the ipart table?  I'm not sure this is doable without some customization.  What version of Inventor are you using?
Chris Benner
Message 18 of 19
johnsonshiue
Hi! I believe you need to add Finish features to the part. Then configure the Finish feature accordingly. Please share an example that you are working on. The forum experts can help take a look.
Many thanks!
Message 19 of 19
CGBenner
@Bhargav_PatelTYWUT
Hello, did the answer above solve this for you?  Or do you still need help?
Chris Benner
