Change units
Change units
mbondY2CD6
Message 1 of 15
Change units
mbondY2CD6
I cannot change the measure units from inches to feet. I can change the units under tools/document settings but that doesn't change the annotated measure units
Replies (14)
Message 2 of 15
mcgyvr
By "annotated measure units" are you referring to the dimensions in a 2d drawing (idw/dwg file?) if so you need to change your dimension style in the idw to use the correct units also.
Inventor allows you to easily model in whatever units you want and dimension (in a 2d drawing) in the same or totally different units if you want without needing to change your modeled units.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2020...
Message 3 of 15
Cadmanto
I am not sure what you mean my annotated measure units.  The measuring tool picks up the same units set in the Document settings.  If you are talking about the units in the drawing, that is set in the styles under the manage tab.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 15
mbondY2CD6
When I press annotate folder and then measure it only shows the value in inches. I have the units set as feet under tools/document settings
Message 5 of 15
Cadmanto
You have not clarified this, @mcgyvr and I have both asked, but based on what you are saying, it sounds like you are talking about in a drawing and you are not measuring, but rather placing a dimension.  Measuring and dimensioning are two completely different functions.
Like I stated in my first posting, you need to edit the styles of that dimension.  See below on how to change it to feet.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 6 of 15
mcgyvr
I'm now assuming you mean the units of the "Annotate" functionality in a part (3d MBD/PMI type dimensions)
If so Autodesk has totally made this as confusing/half finished as they could..
I'll let someone else show you the steps to do that as I started the day out smiling and I would like to stay that way..
Message 7 of 15
mbondY2CD6
I appreciate your patients.  I am trying to evaluate Inventor with the Trial version Inventor 2020.  All I have under Style and Standard Editor is Lighting and Text, not what you are showing above.
Message 8 of 15
JDMather
Can you give a bit of information about what you want to evaluate?
Have you used SolidWorks or Creo (Pro/E).
Are you familiar with Model/Assembly/Drawing environment files (this isn't AutoCAD)?
Modeling environment (3D Annotation in particular)  It would probably be best (as a beginner) to start from a Template appropriate for your intended units rather than changing units after the fact.
Assembly environment? 2D Drawing environment?
Message 9 of 15
mbondY2CD6
Yes I went from Draftsight which is 2D to AutoDesk Fusion 360 3D.  Both I'm pretty efficient in.  Fusion didn't offer enough features for modeling.
Message 10 of 15
mbondY2CD6
Is there a good video package for a beginner?  I understand the modeling concept.  I just need to know where everything is.
Message 11 of 15
JDMather
@mbondY2CD6
Where to start, where to start....
Inventor is different than Fusion 360 as Fusion doesn't follow real-world conventions.
In the real world a part is a part.  A part is not an assembly, apart is not a drawing (2D intended for sheet of paper).
In the real world an assembly is a collection of components (parts or subassemblies).
In the real world a drawing is a 2D representation on a sheet of paper.
Fusion uses one file for all of this.
Inventor uses a separate file for each:
Part file is *.ipt
Assembly file is *.iam
Drawing file is *.idw (or *.dwg)
If you relate these to the real world equivalent then it is quick to get over this hurdle (you can (and should) put all three files into a project folder, so nothing to get concerned about - one folder(Inventor) or one file(Fusion), who cares.  If you stick with it long enough you will see there are very very significant advantages to the Inventor real-world representation of, well, the real world.
There are a bunch of Tutorials in Inventor, not sure of a series that take you step-by-step through a project as it has been 15+ years since I went through the tutorials.
I am in the process of starting a YouTube channel to do exactly this, but I have only just started.
There are a couple of examples of Fusion and Inventor equivalent tutorials here.
The CADWhisperer
I see that you have an interest in Weldments.
I happen to teach a CAD for Welding class and will be adding a bunch of content to my YouTube channel, but that is weeks away from being ready.
If you can Attach one of your *.f3d or *.f3z projects here - I can create a quick video of model/assembly/drawing with welding annotation video using one of your projects.
Message 12 of 15
johnsonshiue
Hi! I believe you are talking about the workflow of changing 3D Annotate unit. This is a bit involved. The process is not that straight forward but it is doable. I will post a screencast to show you the process (see below). You need to save the change in Part and Assembly template files.
https://knowledge.autodesk.com/community/screencast/71729df2-4d7b-4918-9beb-7d7464c40642
Many thanks!
Software Test Engineer
Message 13 of 15
tamasTYXFW
Hello Johnson, I don't see the screencast you mentioned, is it still available somewhere?
Or can someone point me in the right direction on how to change the units for 3D annotations?
Message 14 of 15
johnsonshiue
Hi! Many thanks for bringing to my attention! I was not aware that the screencast link was not posted correctly. I have modified the original reply and included the link. Please take a look.
Thanks again!
Message 15 of 15
tamasTYXFW
Thank you very much, that answered my question!
