Change ReadOnly in Form with iLogic
Hey,
I'd like to manipulate my Form with my iLogic code. Specifically, I'd like to change whether or not a particular Parameter/iProperty is ReadOnly within the form.
I have attached a screenshot showing the Form Editor property that I would like to be able to manipulate from iLogic.
As a side note, is there a way to change whether or not a Parameter/iProperty is visible within the form?
  -Luke
Curtis_Waguespack
Hi nealon.luke,
You'll need a Boolean (True/False) parameter (let's call it Title_Active), then you'll set that as the Enabling Parameter in the settings within the form for the Title parameter.
Then you can set the Title_Active parameter with code in the iLogic rule, based on some condition.
Unfortunately, there is not a way to make a Parameter/iProperty is visible / not visible within the form.
I hope this helps.
Curtis
