Change radial spacing of hole pattern extrusion
Hi all,
I have a fairly complicated hole pattern (hexagons with a number of parametric relationships) that I want to extrude through a flat circular plate while "contracting" the pattern radially, so that the hole centers end up being closer together while the integrity of the pattern and hole diameter is preserved.
I have attached a screenshot of a much simpler mock up part I have been trying to find a viable method to achieve this on.  I've been experimenting with using a sweep with a guide rail to force the pattern to contract through the extrusion, but it also decreases the size of the holes and fails because it says the path doesn't intersect the profile, and the rail doesn't intersect the profile (even though they both intersect a hole center).
Any ideas?
Replies (7)
SBix26
More detail needed:
- Is it a radial pattern?
- Are the hexagonal holes oriented perpendicular to the hole axis (i.e. is the intersection of a hole with the top surface a skewed hexagon or a true hexagon)?
Seems to me that you could create one hole at the correct angle, either by sweep or extrude, and then pattern it?  Or is that too simple?
Best would be for us to avoid guessing and have the actual file to work with.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
SBix26
I've attached a part (2018) for you to look at.  This has a hexagon extruded through the disc at an angle (see below) and then circular patterned.
Is this what you are trying to do?
Sam B
LinkedIn
johnsonshiue
Hi! The warning should be benign. In your case, there are 5 circular profiles and only one intersects the path and one intersects the rail. The warning is legitimate. Maybe, when all 5 profiles are selected in this case, the resultant body is bad. You could try creating one sweep feature based on one circular profile. Then pattern the feature. Does it work?
If you cannot figure out, please attach the part here. Forum experts can help take a look and propose good workflows to achieve desirable result.
Many thanks!
Software Test Engineer
Hi Sam and Johnson,
Thanks very much for your input!
To clarify I have attached 2 parts: the first part has a sketch with the wide hole pattern that I want to be extruded into it with the spacing between holes decreasing and holes staying the same diameter (this is necessary because balls will roll in the channels), and the second part has the tighter hole pattern that I want the transition to.
Unfortunately, the warnings on the sweep don't let me proceed and generate the feature, FYI.
Thanks very much and I hope that helps clarify!
Peter
johnsonshiue
Hi! There should be multiple ways to do this. I have found an interesting solution for the Wide part. Please take a look. I don't get what you want to do with the Thin part though. I guess the same technique can be used there too.
Many thanks!
SBix26
Is this anything like you have in mind?  Note that in order for balls to roll through these channels the holes have to maintain a circular cross section, making their intersection with the top and bottom surfaces elliptical; quite severely so at the outer extremes.  This effect would be reduced if the thickness of the part increased.
Sam B
LinkedIn
SBix26
Here's a better way to accomplish the same result as posted yesterday.
Sam B
LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
