Change part feature (Fillet in this case) face color from Assembly itself
it is my first share, and i am sharing it because as this forum helps me a lot when i need so i feel that i shoud share something which can help someone there.
i wrote this code by modifying code from topic "Re: Change User Parameter Custom Property with VB" by Bg45  in reply to:
Public Sub Main()
Dim R As Byte, G As Byte, B As Byte
R = 255
G = 255
B = 0
Call tryl3(R, G, B)
End Sub
Public Sub tryl3(R, G, B)
'Get the active assembly document.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
'Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
'Check to see if this is a part and part name is "Sketch.ipt".
If oDoc.DocumentType = kPartDocumentObject And oDoc.DisplayName = "Sketch.ipt" Then
Debug.Print oDoc.DisplayName
Debug.Print oDoc.FullFileName
Dim oPartDoc As PartDocument
Set oPartDoc = oDoc
Dim oFeatures As PartFeatures
Set oFeatures = oPartDoc.ComponentDefinition.Features
'Check to see if the part document contains Features.
If oFeatures.Count > 0 Then
Dim oFeature As PartFeature
'Loop through each Feature.
For Each oFeature In oFeatures
'look for oFeature.Type Fillet and Feature Name = "Fillet3"
If oFeature.Type = kFilletFeatureObject And oFeature.Name = "Fillet3" Then
Debug.Print oFeature.Name
Set oFeature = oFeatures.Item("Fillet3")
'MsgBox oFeature.Name 'oUserParam.Value
Dim oTG As TransientObjects
Set oTG = ThisApplication.TransientObjects
Dim oAssets As Assets
Set oAssets = oPartDoc.Assets
Dim oAsset As Asset
On Error Resume Next
Set oAsset = oAssets.Item("Test")
If Err.Number <> 0 Then
Call oAssets.Add(kAssetTypeAppearance, "Generic", "Test", "Test")
Dim generic_color As ColorAssetValue
Set generic_color = oAsset.Item("generic_diffuse")
generic_color.Value = oTG.CreateColor(R, G, B)
Set oFillet = oFeature 'oCompDef.Features.FilletFeatures("Fillet3")
Dim oFace As Face
i = 1
For i = 1 To 24
Set oFace = oFillet.Faces.Item(i) 'The face
oFace.Appearance = oAsset
Next
Next oFeature
Else
Debug.Print "No userparameter is available"
Next oDoc
oAsmDoc.Update
End Sub
Yijiang.Cai
Nice code sample, and really useful!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
