Change flange height
mguman
mguman
Hi there members of the community,
These are 2 flanges made in sheet metal.
As you can see in the image below, the distance between the two faces is 14,36mm. Is there an option to change that? E.g. in my case I want to adjust that distance to 21mm.
CCarreiras
Hi!
It depends on how you did the part.
Can you share the file?
CCarreiras
mguman
Hi CCarreiras,
This is the file.
CCarreiras
Use this Settings:
CCarreiras
mguman
Thanks a lot, this solved the problem.
CCarreiras
...Anyway... it's possible to control the dimensions better for this kind of parts, using this method:
  1. A sketch with all dimensions
  2. Contour Flange
CCarreiras
