Change bom-structure with a custom parameter
stefan.godfroid
stefan.godfroid
Hello
I want to change the bom-structur with a custom parameter (TEKENINGCODE).
The bom-structure must be Purchased when TEKENINGCODE= B, LB, LK, T, D, DS or K
The bom-structure must be Inseperable when TEKENINGCODE= L
The bom-structure must be Phantom when TEKENINGCODE= x
in other cases (other letters, or nothing entered), then the bom-structure must be normal.
How can i do that with I-logic?
Sergio.D.Suárez
in part, you can use an ilogic like this, changing the multiple value will change the BOM reference
Dim oDoc As Document = ThisApplication.ActiveDocument
'kDefaultBOMStructure 51969 The default structure type.
'kInseparableBOMStructure 51974 The inseparable structure type.
'kNormalBOMStructure 51970 The normal structure type.
'kPhantomBOMStructure 51971 The phantom structure type.
'kPurchasedBOMStructure 51973 The purchased structure type.
'kReferenceBOMStructure 51972 The reference structure type.
'kVariesBOMStructure 51975 The structure type varies amongst references.
' TEKENINGCODE is user parameter in part
If TEKENINGCODE ="L"
oDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
Else
	If TEKENINGCODE ="x"
	oDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	Else
	oDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
InventorVb.DocumentUpdate()
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
stefan.godfroid
But TEKENCODE is a Custom iproperties.  Sorry for the wrong info.
And the purchased bomstructure?
When the Custom ipropertie TEKENCODE= B, LB, LK, T, D, DS or K,  then the bomstructure must be set to Purchased.
When the Custom ipropertie TEKENCODE= L, then he bomstructure must be set to inseperable
When the Custom ipropertie TEKENCODE= x, then he bomstructure must be set to phantom
In other cases (other letters, or nothing entered), then the bom-structure must be normal.
How can it be done with ilogic?
Sergio.D.Suárez
Hello, you can try the following code, I think it should work.
oDoc.ComponentDefinition.BOMStructure = 51970
On Error Resume Next
Dim oProp As String = iProperties.Value("Custom", "TEKENINGCODE")
If oProp = "L" Then oDoc.ComponentDefinition.BOMStructure =  51974
If oProp = "x" Then oDoc.ComponentDefinition.BOMStructure =  51971
If oProp = "B" Or oProp = "LB" Or oProp = "LK" Or _
	oProp = "T" Or oProp = "D" Or oProp = "DS" Or oProp = "K" Then
	oDoc.ComponentDefinition.BOMStructure = 51973
 I hope this helps. Regards
Mechanical Designer
stefan.godfroid
It seems to be working!
Thanks!
